What is the difference between Ada-C/C++ Changer and an Ada to C language syntax converter?
Ada-C/C++ Changer is not an Ada to C language syntax converter, which is very inefficient. Ada-C/C++ Changer technology is actually an Ada compiler along with a few command line switches that are used to perform Ada to C conversion. Since the conversion is performed via a compiler engine, the resultant code is optimized and guaranteed to execute. ‘C’ compiler can then be used on the resultant C code, which provides double optimization, therefore, the performance of the resultant C code is not compromised but optimized.
