How to perform Embedded Memory management in conversion?
We have C++ template types which can lay out data structures to the bit same as Ada compiler as specified in the Ada representation clauses
Related Articles
How do you support Memory Management - VM, Shared Library, demand paging etc? If yes, is it "arm-linux-eabi" complaint?
Mapusoft support ANSI memory, dynamic pool memory, partitioned memory, tiered pool memory (dynamic memory build using layers of partitions like a wedding cake) and then shared tiered pool memory and also general shared memory area. Memory is fully ...
How is memory defragmentation handled in the OS Abstractor product on Linux and VxWorks?
OS Abstractor always prefers to use the OS defrag methods for pools created using OS_Create_Memory_Pool API. Under VxWorks, the pool management and defrag is handled by the OS itself. Under Linux, we have two options: Option 1: This is a preferred ...
Is all access to a memory pool serialized among all threads (tasks)? Does each thread lock the memory pool when allocating or deallocating from that memory pool?
The memory allocation is FIFO based across all OS. There are two types of memory allocation to be discussed: Fixed Memory Allocation: OS Abstractor does NOT synchronize the alloc/de-alloc request. Neither does it searches memory to find a free block. ...
