Can OS Abstractor and Interface libraries be built as shared libraries? What about as DLLs?
OS Abstractor and Interface libraries can be built as shared libraries. This would be the recommended option if you develop multi-process applications. As far as DLL, the current release does not support this feature. However, MapuSoft can provide custom help for your specific target environments.
    • What are the important design goals of OS Abstractor?
      Portability and Performance are key factors, which go hand in hand. Next is the API simplicity and development flexibility. The APIs are designed in such a way that they can be extended easily with new features and still preserve backward ...
    • Does OS Abstractor dynamically allocate memory at run-time?
      OS Abstractor library allocates memory for all the control blocks, application memory pools and such either statically or during initialization. This is done to ensure that OS Abstractor provides a stable environment for the application. The run time ...
    • What is OS Abstractor and Cross OS Development Platform?
      Cross-OS Development Platform™ is a C/C++ source-level virtualization technology that provides a robust and industry standard OS interface architecture for flexible real-time application development, while allowing the user to protect the software ...
